Ford 5000 misfire
/ Ford 5000 misfire #1
2006gmcdmax
Augusta, GA
Many but mostly ford diesels or ihc or jds
My tractor got ran out of fuel. It started misfiring so of course I primed it back up got it running again started to misfire. We'll we came to the conclusion the timing was a little high. So we set it back to 19 ran even worse. So I set on 24 zero misfiring runs strong as ever and cleaned up the smoke from turning the pump up about half a turn. Why would advancing the timing to 24 make it run so good?
/ Ford 5000 misfire #3
Assuming that 19 degrees is correct for normal fueling, with more fuel, the ignition delay may be longer thus requiring more advance.
/ Ford 5000 misfire
We'll whatever it was she runs great now not too Ricky sounding either
