Ford 5000 lost nearly all power
   / Ford 5000 lost nearly all power #1
blackeye
philomath oregon
Ford 5000
Cutting hay today, when the tractor lost nearly all power. Starts/runs, but if on a slight incline, will slow to a stop
even though engine keeps running. RPMs seemingly irrelevant. Disconnected the mower, and drove it back to the barn.
Will run in first and second slowly on the hills; higher gears possible only on the flat. Shifting seems more difficult.
Tractor newbie, and in the middle of haying, and my mechanic just moved out of town. Help!
   / Ford 5000 lost nearly all power #2
Sounds like clutch issue.
   / Ford 5000 lost nearly all power #3
If you have it in first gear and step on the brakes (without touching the clutch), does it stop moving or bog down the engine? If the brakes don't hold it, try pushing on a tree. If the wheels don't spin, you probably need a new clutch.
Aaron Z
Aaron,
Just tried this. Stops easily braking in first. This means new clutch?
   / Ford 5000 lost nearly all power #5
How long since the fuel filter has been changed? How air filter?
Edit. I just noticed you said shifting is difficult.
   / Ford 5000 lost nearly all power #6
Aaron,
Does the engine bog down and stall out when it stops? If the engine does not bog down when the tractor stops that means you will need a new clutch (there is a remote possibility that the linkage needs to be adjusted, but either way, I would have a mechanic look at it).
Aaron Z
   / Ford 5000 lost nearly all power #7
G'day check to make sure clutch pedal has free travel might get lucky and only need an adjustment
Jon
Aaron -- No bogging down at all. Engine purrs and seems to not notice that I'm standing on the brake without depressing the clutch.
Jon -- Clutch seems to travel freely, so perhaps I'm unlucky. But I'll check this out more thoroughly.
Tom -- fuel filter changed last month. air filter cleaned out last week.
Thanks for all your replies. I'm hoping to get someone out here today to diagnose it.
   / Ford 5000 lost nearly all power #9
Sounds like a bad clutch then, if its linkage any competent tractor mechanic should be able to check and adjust that if needed.
Aaron Z
Mechanic came today and adjusted the clutch rod. Seems to stay in gear now. Shifting is easier, though he thought there were
probably issues in the clutch. Gonna try to finish the hay and reassess. Thanks again.
UNUSED HURRICANE D6028 - 5' JOB BOX (A51248)
UNUSED HURRICANE...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
City of Buckhannon - 2000 Chevy 2500 (A52384)
City of Buckhannon...
2021 JOHN DEERE 8R 370 LOT IDENTIFIER 175 (A53084)
2021 JOHN DEERE 8R...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
UNUSED FUTURE CYHC HYD SIDE SHIFT FORKS (A51248)
UNUSED FUTURE CYHC...
