Ford 5000 lift issue
   / Ford 5000 lift issue #1
2006gmcdmax
Augusta, GA
Many but mostly ford diesels or ihc or jds
Lift arm will not lift I can pick up freely, pto does work! which valve could be acting up? thanks
   / Ford 5000 lift issue #2
Does it have fel.if not there is a relief valve on the cylinder block that will get stuck or a blown o-ring where the lift top sits down the best i remember it has been a while sense worked on one . If got fel there is a valve under the set (not all have them)that I have seen get moved by getting on and off tractor bumping it with there leg and moving the valve
I figured it out it was the bypass valve and the u loader valve was stuck
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
TAKEUCHI TL230 SERIES II SKID STEER (A51246)
TAKEUCHI TL230...
1995 GMC CHIPPER/BUCKET TRUCK (A52576)
1995 GMC...
