Ford 5000, Kelley front end loader 800 model
   / Ford 5000, Kelley front end loader 800 model #31
To bleed air out of a hyd system, just cycle the cyl's several times, and if necessary, do it again. In most cases, when you pump fluid in, fluid and air come out.
Thanks again JJ. Ok, I put in a gallen, then another and antoher finally 4 gallens and it worked. Went in to get the wife, started it up again, and nothing.
put in another gallen, and nothing. So maybe the lines filled up, lowered the overall level below what it needs to work again. Tomorrow, I will get 5 more gallens, and add one at a time to see what happens. I have all leaks fixed. No leaks anywhere now.
I got two new hoses, but they put the wrong ends on one of them. but anyway, I will get them to fix that tomorrow.
I don't know where 5 gallens went, unless it cyfiended off, when I was getting the new hoses. Then it was the next day before I put them on. I guess thats what happened or it was pretty low to start with. Maybe the dealer only put in enough to get by.
OH yeah, I put a stick in till it bottomes out on the houseing and nothing shows on it yet.
PUt in a sixth gallen, Can't even see it or reach it with the stick still. I understand it only holds 8.7 gallen
Where could it be going, I do not see any leaks anywhere.
   / Ford 5000, Kelley front end loader 800 model #33
Your brother said you've got water in the tranmission. He's a diesel mechanic, can he give you a hand with this?
can you post a picture of this tractor?
Yes, my brother will be helping me with this. Help helped me buy it. But is throughly pissed about what Rudolph Bros did to me about the year difference. He is thinking about us getting a lawyer and sueing them for fraud. Monday we are going to the Lincoln county prosecuting attorneys office and file charges.
Does anyone know how many gallens I need for the Transmission change.
Its been suggested, that I fill the tranny with Diesel fuel, let it set, then drain it, and fill it with the tranmission/Hydrolic fluid.
That just don't sound right to me. What you you old experts say?
   / Ford 5000, Kelley front end loader 800 model #36
If that's the case I suggest you keep careful records of everything you have done to this machine, documented with photos.
This law suit will take years, Rudolf (you already know they are liars and thieves) will place blame on you for the damages.
What about the photo?
thank god my little brother was more succesful in life than me, He has deep pockets. Yeah.
But, I am the one with a university education. Not that that, made the difference.
   / Ford 5000, Kelley front end loader 800 model #38
no bleeding other than running cyls in and out multiple times.
soundguy
   / Ford 5000, Kelley front end loader 800 model #39
i'll check my 5000 manual when i get home.. for the multi sump unit.
for the common sump unit.. it's plenty. IE.. 10-13 gallons depending on hyd usage.
wonder just HOW LOW yours was if you've added a few gallons and not got it out of the check port.
soundguy
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2015 Isuzu NRR John Bean 700 Sewer Jetter Vacuum Truck (A49461)
2015 Isuzu NRR...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2016 CHEVROLET SILVERADO 2500 HD CREW CAB TRUCK (A51243)
2016 CHEVROLET...
2000 Dnya RGN T/A Trailer (A49461)
2000 Dnya RGN T/A...
Nissan 5k Forklift (A51039)
Nissan 5k Forklift...
