Ford 5000 hydraulic question batwing mower
   / Ford 5000 hydraulic question batwing mower #1
2006gmcdmax
Augusta, GA
Many but mostly ford diesels or ihc or jds
Looking to buy a batwing 15' bush hog. does anyone know what all I need to make it work and be able to operate the up and down of the mower and the wings hydraulic wise? It has a single remote on the back.
   / Ford 5000 hydraulic question batwing mower #2
A 3:1 Fasse valve or similar will allow independent operation of each wing and the lift. A 3 spool valve bolted to the fender would accomplish the same thing. Both would be supplied by the existing remote.
Could you send me some part numbers by any chance
Also can I operate both wings seperately and raise and lower seperately
What gallon per hour valve would I need and the 5000s are 2000 psi on the hydros right
   / Ford 5000 hydraulic question batwing mower #6
depending on how your wing is set up ( 2 ckts vs 3 ckts ).. a 2 or 3 spool valve will be needed as rick said. OC.. just lock yous into flow and then work the other valves.. then unlock yours.
I used my 5000 w/ single remote on my 2 ckt wing just to tender it around the farm.. used a dual spool logsplitter valve.
later on.. my 7610s got to play with the wing.. and it had 2 remotes.. etc..
I called fasse alittle pricey but hey it's worth it it'll be nice and simple. Do you know anyone wanting to sell a allis chalmers d19 turbo
   / Ford 5000 hydraulic question batwing mower #8
If the cyl are sequenced, one spool valve will work.
However, a three spool valve connected to each cyl will do what you want independently.
You can do this with three solenoid valves but at full flow, or lever valve and feather the cyl to operate slowly. A needle vale can adjust how slow.
   / Ford 5000 hydraulic question batwing mower #9
Full flow is about 8 GPM @ WOT. Too much flow won't be an issue. A Fasse valve will direct flow while using the original spool valve to control flow.
Thanks guys I talked to fass he said their switch basically just selects what spool then you use the normal spool as the feed to whatever valve
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
UNUSED HURRICANE 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
2004 Ditch Witch RT70M Ride On Trencher (A53117)
2004 Ditch Witch...
Adams 5 T Spreader (A53472)
Adams 5 T Spreader...
HURRICANE 6' X 11' CONTAINER (A51248)
HURRICANE 6' X 11'...
2024 KUBOTA KX080-4 S2 EXCAVATOR (A51246)
2024 KUBOTA...
