Ford 5000 Engine Rebuild to 7000 specs with Turbo Possible?
   / Ford 5000 Engine Rebuild to 7000 specs with Turbo Possible? #1
Kevinford5000
Madera, CA
Ford 5000
I have a 1972 Ford 5000 Diesel that Belows Blue Oil Smoke. I am thinking it is time for a rebuild. I would like to add a turbo for more power, ideally from a Ford 7000. The Engines between the two are the same size. Does anyone know if I can do this retrofit successfully? Will 7000 internals fit? What needs to be changed? Anyone completed this?
   / Ford 5000 Engine Rebuild to 7000 specs with Turbo Possible? #2
It is the same engine but probably different pistons and maybe piston cooling so the connection rods are different, you must give it more fuel so the pump must be tuned.
But what use are it? The 7000 was designed to go day in and day out and at full power, suppose you use it quite different?
2006 INTERNATIONAL PAYSTAR 5500I KILL TRUCK (A50854)
2006 INTERNATIONAL...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2003 PETERBILT 330 CARGO TRUCK (A50854)
2003 PETERBILT 330...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
