Ford 5000 Engine Rebuild to 7000 specs with Turbo Possible?
   / Ford 5000 Engine Rebuild to 7000 specs with Turbo Possible? #1
Kevinford5000
Madera, CA
Ford 5000
I have a 1972 Ford 5000 Diesel that Belows Blue Oil Smoke. I am thinking it is time for a rebuild. I would like to add a turbo for more power, ideally from a Ford 7000. The Engines between the two are the same size. Does anyone know if I can do this retrofit successfully? Will 7000 internals fit? What needs to be changed? Anyone completed this?
   / Ford 5000 Engine Rebuild to 7000 specs with Turbo Possible? #2
It is the same engine but probably different pistons and maybe piston cooling so the connection rods are different, you must give it more fuel so the pump must be tuned.
But what use are it? The 7000 was designed to go day in and day out and at full power, suppose you use it quite different?
2008 International CF500 Electric Lift Service Truck (A48081)
2008 International...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2004 FREIGHTLINER COLUMBIA 112 MID-ROOF SLEEPER (A50854)
2004 FREIGHTLINER...
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
