Ford 5000 and IH 480 disk hyd qd
   / Ford 5000 and IH 480 disk hyd qd #1
Fred Smith
Does anyone know if the qds on an IH 480 disk will fit in a Ford 5000 tractor.
Thanks in advance
   / Ford 5000 and IH 480 disk hyd qd #2
Impossible to answer definitively. The hydraulic tips on the disc were matched to whatever tractor pulled it in its previous life.
   / Ford 5000 and IH 480 disk hyd qd #3
Rick is right. What you need to do is check to see what tips it has and if they are the correct tips then you are set. If not you buy the right tips and change them.
   / Ford 5000 and IH 480 disk hyd qd #4
Exactly,
Tips are cheap, usually around $5 a piece. We keep them in stock just in case we buy something and need to swap them off.
Thanks, the disk and the tractor are about 100 miles apart untill tomorrow and i was hoping to be able to get some spare tips but the local tsc is wiped out. thanks again
   / Ford 5000 and IH 480 disk hyd qd #6
go to your tractor dealer and get some from him
OK here is what I have. the male tips are to large for the tractor/female side. going to new hollund today but ill take any suggestions you might have.Thanks.
   / Ford 5000 and IH 480 disk hyd qd #8
What I would do, is to take off the QD's on the tractor, and clean them up really good, and take them to a hydraulics place and see if they can match. The other way is to get some matching sets of whatever, or match up to what you already have on other implements. There are many look-a-likes. They can be anywhere of $20 for a set, or up to $60 for a set. You could also go to flat faced connectors if you wanted to connect under pressure.
   / Ford 5000 and IH 480 disk hyd qd #9
You need a pair of ISO (also called Pioneer style) male tips with 1/2" npt threads. Common as dirt, the most common and popular male tip used in the AG world. The tips on the disc fit 66 and 86 series IH tractors and nothing else I know of.
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51243)
(NEW) 2025 DOWN 2...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2013 Isuzu NPR-HD 16FT Reefer Box Truck (A50323)
2013 Isuzu NPR-HD...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2023 TAKEUCHI TB370 EXCAVATOR (A51242)
2023 TAKEUCHI...
New Idea Tandem Manure Spreader (A50774)
New Idea Tandem...
