Ford 4630 Leaking PTO Shaft Seal
   / Ford 4630 Leaking PTO Shaft Seal #1
HickoryNut
Central Arkansas
Is the 4630 a simple remove cover and replace seal -or- does it require shaft removal and dealing with thrust washers like I'm reading about on the similar active thread for the 3000 model?
Shaft has no play and it only leaks enough to attract dirt, I'll wait till dead of winter if the seal repair involves possible downtime.
Thanks
   / Ford 4630 Leaking PTO Shaft Seal #2
If it is a single speed pto, then drain oil down below cover, remove and replace seal.
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
1985 Ford Ltl9000 Tender Truck (A53472)
1985 Ford Ltl9000...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
