beggar
Bronze Member
- Joined
- Jun 1, 2014
- Messages
- 51
- Location
- picayune,ms.
- Tractor
- farmtra555-case1494-kubota M4050-F4610-MF285
I am adding aux. hyds to a 1984 4610. I put on an adapter plate and ran hoses to a single spool valve.The plate is stamped with a"P" for pressure side.I hooked it to "in"port on spool valve.I hooked it up to a batwing rake.I had to kill the tractor because I had fluid pressure on one hose,but not full pressure but a heavy flow.When I hooked it up it raised up but leak right back down.I switch hoses and same thing.I took the spool back and got another just like it.It did the same thing.I swap the "P" hose to the out side"return" of the spool and got the same thing.All the holes on the adapter plate lined up and it looks ok there.both spools were rebuilt.Could it be two bad spool valves or the wrong application.anybody got any ideas.Help appreciated.
