Ford 4610 rear remotes leaking. Rebuildable??
   / Ford 4610 rear remotes leaking. Rebuildable?? #1
Fordper4mance
Somerset Ohio
Ford 4610
I have an 88' Ford 4610 with dual rear SCVs. One or more of the outlets are leaking and I need to know if they can be rebuilt or serviced. Here is the pic of the unit. It has the numbers 26-05-052-901 stamped in the casting. Any info about this is greatly appreciated.
   / Ford 4610 rear remotes leaking. Rebuildable?? #2
You can replace the coupler barrels and convert them to leverless style at the same time.
Can you tell me where to find these parts. I've searched for replacement parts for the unit but didnt find anything
   / Ford 4610 rear remotes leaking. Rebuildable?? #4
New Holland part #F1NNS938AB is the conversion kit. Not sure if one kit updates a single coupler body or the coupler pair on one remote valve.
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
10x16.5 Tire Assembly (A52748)
10x16.5 Tire...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
