Ford 4610 Lift arms leak down
   / Ford 4610 Lift arms leak down #1
Blaze08
Ga
Mahindra 4530/Ford 4610
As the title states the lift or pick up arms will leak down and you aren't able to set at a constant height. Any thoughts?
Anyone?
   / Ford 4610 Lift arms leak down #3
Are they leaking down while running or while parked?
   / Ford 4610 Lift arms leak down #5
Have you checked fluid level?
Yes...
   / Ford 4610 Lift arms leak down #7
Do you have remotes where you can check pressure with a gauge?
   / Ford 4610 Lift arms leak down #8
I'm not much help with hydraulics, there are more knowledgeable members I'm hoping might chime in.
   / Ford 4610 Lift arms leak down #10
Does the 3pt jump as in it's trying to maintain a certain height, this would be a leak in the lift cylinder.
Or, you can't set the position of the implement and when you try, it falls all the way down or raises all the up. If this is the case, then you are using the draft lever, the one on the inside of the quadrant OR you have a problem with your linkage. You could also check to see it the top link draft yoke has slop in it. That's the one with the big spring on the top of the axle housing.
2002 Ford F350 Dually Pick-Up Truck w/ RECON Title (A49251)
2002 Ford F350...
2016 KENWORTH T680 TANDEM AXLE SLEEPER (A50046)
2016 KENWORTH T680...
2010 Doosan DX225LC Trackhoe (A49251)
2010 Doosan...
82" Pallet Fork Extensions, New (A47371)
82" Pallet Fork...
2025 70in Dual Cylinder Grapple Skid Steer Attachment (A49346)
2025 70in Dual...
60" Pallet Forks, New (A47371)
60" Pallet Forks...
