Ford 4610 II - Lube and Oil Basics
   / Ford 4610 II - Lube and Oil Basics #1
TracThor
Arkansas
Brrrm
Dear all,
Quick question, regarding a Ford 4610 II this time. Basically, what lube's and oils go where, and how much? Where are the drain holes, level indicators, etc? Particularly interested in the rear at this point, as it seems the hydraulics may share oil with the diff?
Edit: Should mention I'm pretty new to tractors so bear with if this should all be obvious to me.
Cheers,
TracThor
   / Ford 4610 II - Lube and Oil Basics #2
Do yourself a favor and buy an operator’s manual. Answers to all that plus questions you don’t know you will ask.
New Holland 134 hydraulic oil (or equivalent) in the transmission, rear axle and power steering. 15W-40 or 10W-30 CI-4 or higher rated engine oil and heavy duty DCA/SCA fortified antifreeze.
Heya Rick, thanks mate - where would I source such an operator's manual?
   / Ford 4610 II - Lube and Oil Basics #4
   / Ford 4610 II - Lube and Oil Basics #5
   / Ford 4610 II - Lube and Oil Basics #6
Google search for a manual. I bought an electronic version and printed it.
When I'm at home later today I'll try to remember to add it to this thread.
   / Ford 4610 II - Lube and Oil Basics #7
Engine oil 15w-40 C (compression) rated 7 qt, Oil filter Motorcraft FL-1A, Tranny (3 gal cap) and diff/hyd (about 12 gal cap)Ford.......134 BC.
Engine drain on left side of engine oil pan, fill 1 ï½½" black knob on left side half way down about 6" toward the rear from radiator shroud.
Tranny drain under tranny, fill on top of tranny cover, dip stick on tranny cover...fill to top line.
Diff/hyd, drain plug is partially hidden by the tow bar, near the front....3/8" female square hole in pipe plug, fill on top of differential casting just to the side of where the 3 pt top link mounts, may have 2 plugs up there, one on either side...use either, full plug ⅛ pipe male square plug stuck in the side of the diff/hyd casting, half way up, just behind the flow control knob and protrusion immediately inboard of your right heel when pressing differential lock lever.
Power steering 10w-30 motor oil, fill till it runs out the hole where the cap sits on top of the pump shroud, left side of tractor about 6" back from the same radiator shroud mentioned above, just on other side of tractor. Cap is ¼ turn and hard to get off....should be a gasket under the cap....if not fluid will leak out.
   / Ford 4610 II - Lube and Oil Basics #9
Too heavy. Look for a universal tractor fluid. Kendall Hyken 052, Mobil 424, John Deere HyGard, Kubota UDT, Chevron THD 1000, and Gulf Universal Tractor Transmission fluid are some you may find in OZ.
   / Ford 4610 II - Lube and Oil Basics #10
JD 303 oil is about as popular as you can get. Here Wallmart sells it besides most any auto parts jobber located in or near farming areas. The 303 is applicable to the same time period as your 134 B/C. It's like 20w......you have wet brakes and probably IND PTO like mine with clutches, both require a thin oil, not "gear oil" like 80 to 140 GL 1-5 type thing.
I got my I &T Shop manual day before yesterday (#43) which covers mine and yours and 2 smaller units. All use the same fluids so I am right on with the recommendation.
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
Case 821F Articulated Wheel Loader (A51691)
Case 821F...
2022 INTERNATIONAL MV607 (A52472)
2022 INTERNATIONAL...
2000 Ford Ranger Pickup Truck, VIN # 1FTYR10V0YTA06580 (A51572)
2000 Ford Ranger...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
