Ford 4600 stuffed Hydrualics
   / Ford 4600 stuffed Hydrualics #1
Jeff_Paul
Comment: I own a Ford 4600 tractor and am having problems with the hydrualics. With out the slasher on the 3 pl it will go up and down,when I put the slasher on ,it only takes the weight and stops .The tractor also has an aftermarket front end loader fitted and this operates very very slowly as is the 3pl The front end loader lifts to full height and loads the hydrualics up and the reliel valve opens,and the engine also labourers a little.The problem started when the slasher dropped quickly and loaded the hydrualics and sheared the bolts holding the two parts of the internal hydrualics together.This has all been reassembled by a hydrualic mechanic but is not working correctly. Has this happened to anybody before and can any-one help me help my tractor , I am lost without my tractor!!!!!!!!!! Thank you Jeff Paul
   / Ford 4600 stuffed Hydrualics #2
i will need to now what parts of the three point cover were reassembled and if they reajusted the cover when they put it on Gary
199049 (A51243)
199049 (A51243)
New/Unused Gold Mountain Container Shelter 20ft x 20ft (A51573)
New/Unused Gold...
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
2015 Dodge 5500 4X4 Bucket Truck (A53472)
2015 Dodge 5500...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
