Ford 4600 stuffed Hydrualics
   / Ford 4600 stuffed Hydrualics #1
Jeff_Paul
Comment: I own a Ford 4600 tractor and am having problems with the hydrualics. With out the slasher on the 3 pl it will go up and down,when I put the slasher on ,it only takes the weight and stops .The tractor also has an aftermarket front end loader fitted and this operates very very slowly as is the 3pl The front end loader lifts to full height and loads the hydrualics up and the reliel valve opens,and the engine also labourers a little.The problem started when the slasher dropped quickly and loaded the hydrualics and sheared the bolts holding the two parts of the internal hydrualics together.This has all been reassembled by a hydrualic mechanic but is not working correctly. Has this happened to anybody before and can any-one help me help my tractor , I am lost without my tractor!!!!!!!!!! Thank you Jeff Paul
   / Ford 4600 stuffed Hydrualics #2
i will need to now what parts of the three point cover were reassembled and if they reajusted the cover when they put it on Gary
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2015 DODGE RAM...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
Mini Skid Steer Sweeper Attachment (A51573)
Mini Skid Steer...
