Ford 4600 engine vibration. Help!
   / Ford 4600 engine vibration. Help! #1
sawtooth
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
So my 4600 runs smooth except from 1600-1800 rpms. Anything above 1800 is fine also. Any idea what could cause a vibration in this 200 rpm range? Do these engines normally run this way. I know it's a 3 cylinder but the vibration is a little uncomfortable so I end up running below 1600 or above 1800 to bypass it. Any ideas?
Anyone?
Update. Well it ended up being dirty injectors. I ran heavy dose of Opti-Lube for 2 tanks and now smooth as can be. Still going to use that stuff but at lighter normal dose rate. Food for thought incase anyone else has same type issues.
   / Ford 4600 engine vibration. Help! #4
Also older tractors don't get enough lube through the fuel any more so put an ounce of eng. oil or two stroke oil to the gallon of diesel.
Gary
Also older tractors don't get enough lube through the fuel any more so put an ounce of eng. oil or two stroke oil to the gallon of diesel. Gary
Thanks but that's me main advantage of Opti-lube. It had highest lubricity rating while cleaning injectors, increasing Cetane, providing a anti gelling agent, and fuel stabilizer. Your right though needing lubrication for the old mechanical injectors.
FIMCO 60 GALLON SPRAYER (A52708)
FIMCO 60 GALLON...
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
TOTE OF RIMS (A58214)
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
2013 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2013 POLAR TANK...
AM GENERAL M1123 HMMWV 2 DOOR TRUCK BODY (A58214)
AM GENERAL M1123...
