ford 4600 4wd
   / ford 4600 4wd #1
gregrsv
glencoe argyll
ford 4600
Hello
Im new to the forum, so this is my first post apart from the introductions post.
I've been looking at a 4600 (1981-82 model) with Q cab.
It has a 3pt linkage and a front end loader fitted , it has a ford distribution ( single spool i think) valve with one control handle and 3 detented positions.
Ive tried the pressure guage in the out put to the FEL and also tried the port for the tipping trailer, the syptoms appear the same for both ports.
With engine running i select the aux valve distribution lever to the required port , nothing happens for a second or two then you hear the pump building a bit of pressure, the pressure sits around 40-50 bar then surges to 115-120 bar for a short spike then back down to 40-50 bar , this continues until the aux valve is deselected.
Using the hyds on the loader or the 3 pt linkage shows corresponding symptoms, the loader lifts ultra slowly in short jerks of an inch or two at a time, the 3pt link is the same.
Another thing is the PTO is not working either it has a hid pro engagement i believe.
I'm not sure if anything in the aux valve distribution block could cause this and i tried to measure pump pressure at the port on the actual pump casing to see if there is any pulsing down there. but i don't have an adaptor of the correct thread to go in there, it looks like the same coarse thread as a mini mess connector on some test points but the test point i had wouldn't start easily so i didnt want to continue and damage the thread.I was trying to eliminate whether the problem was up in the aux take off housing or down at the pump end. I'm not all that clear about this system even after reading the workshop manual it doesn't seem to have a hyd schematic.
Our next plan is hopefully test pump pressure ( does the pump offload itself when not selected by the aux take of valve or should i see pressure all the time there?)
Then possibly remove pump to see if there is any way it could be drawing air in the suction side ( is that the spigotted connection inside as you pull the pump out of the transmission housing?)
Can i get to the pump suction gauze without taking the top cover off?
We are hoping not to need to take the top lift cover off due to the q cab and it looks pretty space restricted.
Has anyone seen similar symptoms with this model that may reduce my fault finding route as i am just finding my way around this machine?
Oh by the way its a single pump machine
thanks very much
Greg
(5) GOLF CART CANOPIES (A51248)
(5) GOLF CART...
J BAR SD5 5' ROTARY MOWER (A51247)
J BAR SD5 5'...
Terex Loader Arm with Bucket (A51691)
Terex Loader Arm...
Generac Generator (A51691)
Generac Generator...
UNUSED CFG HANG-ON PALLET FORKS (A51248)
UNUSED CFG HANG-ON...
