ford 4500 what's this lever for
   / ford 4500 what's this lever for #1
somanytractors
atlanta, ga
several
Can anyone tell me what this lever is for. I can't find anything on it.
It pulls out from the casing and then you can move it down.
Thanks for any help :)
John
   / ford 4500 what's this lever for #2
It could be a flow diverter to power backhoe // 3pt. Can't be used at same time.
   / ford 4500 what's this lever for #3
Select-o-speed transmission? It is the traction disconnect. Allows you to roll/tow a non-running tractor.
That sounds right. I cant think of anything else it would be. The hydraulics are on the front of the loader and it has no pto or 3pt.
What you said makes sense.
I believe it is a select-o-speed. It has 4 speeds and then a lever to change from forward to reverse. Automatic clutch.
Thanks again:)
   / ford 4500 what's this lever for #5
That's not a Select-o-speed transmission it is a 4 speed Power Reversing transmission. But it could be a transplant into a SOS tractor.
   / ford 4500 what's this lever for #6
I found a manual online and it said it was a driveline disengagement lever.
   / ford 4500 what's this lever for #7
This is what I found.
2020 Big Tex 22GN25T5 30' Gooseneck Trailer, VIN: 16V6X2528L6050344, Tandem Axle, Wood Deck, Bad (A59076)
2020 Big Tex...
Willmar 4550 Wrangler Articulating Loader (A56435)
Willmar 4550...
2007 Pierce Dash Pumper Fire Truck (A55973)
2007 Pierce Dash...
ISUZU DUMP (A56858)
ISUZU DUMP (A56858)
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
