ford 4500 tractor, not sure if my starter is up to par
   / ford 4500 tractor, not sure if my starter is up to par
I finally got around to putting an electric fuel pump in it.
It's a totally different tractor now. Starts right up every single time.
Idles smooth.
No need for the intake heater.
Doesn't matter if its at idle, full throttle, or anywhere between.
Starts right up every time.
Now I got to figure out whats going on with the power steering and I'm probably still going to check the injectors to make sure they are working right and maybe play with the pump timing a bit as it has a little more diesel knock then I like, but the starting issue is 100% fixed!
2025 Kivel 48in Forks and Frame Tractor Loader Attachment (A46683)
2025 Kivel 48in...
2016 Ford F-350 Crew Cab Service Truck (A48081)
2016 Ford F-350...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
2013 KENWORTH T800(INOPERABLE) (A48992)
2013 KENWORTH...
LoadMaster 23ft Tri-Axle Boat Trailer (A48082)
LoadMaster 23ft...
