Ford 4500 oil leak....fix?
   / Ford 4500 oil leak....fix? #1
Mtnbktrek
Ford 4500
Hey I have a ford 4500 backhoe/loader and under the case dead center dead middle there is a square plate w 4 bolts and I have a steady drip I think it's hydro fluid....I was wondering if that is just an inspection plate or is a **** ton of fluid going to come out if I remove the plate ....this is a torque conv 4 Spd trans and I have only had it for less than a year and do not kno anything about it... Any help? Thx
Nobody???????
   / Ford 4500 oil leak....fix? #3
A picture or so would help to clarify your question. You are indicating that the leak is from a plate located in the center of the underside of the transmission housing. If so, you should plan to collect the transmission oil. Don't know the capacity of that trans.
2006 Ford Econoline Van w/ Title (A49251)
2006 Ford...
132901 (A48837)
132901 (A48837)
Hot Water Boiler (A49251)
Hot Water Boiler...
Femyers Co. HydraFlush, Culvert/Pipe Flush Unit   (A47371)
Femyers Co...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
377887 (A48837)
377887 (A48837)
