ford 4500 injector pump
   / ford 4500 injector pump #1
m4500
ford
i have a ford 4500 with a 201 diesel engine. I had the injector pump rebuilt about 10 years ago has less then 120hrs since. checked oil yesterday and over full. Front injector seal leaking into crankcase. Has anybody pulled the front drive off of pump to replace seal. Looks pretty easy my only question is when you pull off drive hub off pump shaft splines will it only go back one way or can you get it out of time? Other then that pump is good a shop wants to rebuild whole pump .
haven't taken pump off yet just trying to get parts first. can you buy just the seal?i haven't found it anywhere. is it some thing special or is or is it just a regular lip seal or do i need to tear it it a part first and try and match the seal
is there only one seal or are there two a couple sites claim that you need two on front input shaft?
   / ford 4500 injector pump #6
Take it apart and order what u need..
If u have a tapered shaft with a 7/8” nut, it can be 1 or 2..
If u have a drive hub w an Allan screw in the center and 3 -1/2” bolts holding the drive gear to the pump.. there’s only 1 seal..
If u have one that takes 2 seals, the p# is 5393-252R..
And the one seal is 5393-252U..
U should find the tear down and rebuild manual online, otherwise u need to send it off..
2022 Caterpillar 304 Mini Excavator (A46683)
2022 Caterpillar...
More info coming soon! (A46683)
More info coming...
26ft Truck Body Box (A49251)
26ft Truck Body...
Pallet of (8) 8 Lug Misc Wheels (A48837)
Pallet of (8) 8...
KUBOTA M9540 TRACTOR (A48992)
KUBOTA M9540...
2008 Toyota Tacoma 4x4 Ext. Cab Pickup Truck (A46684)
2008 Toyota Tacoma...
