ford 4500 backhoe
/ ford 4500 backhoe #1
jbrundo
i recently purchased a ford 4500 tractor with backhoe attachment. i replaced all of the hydraulic hoses due to them being wore out. where they attach to the pump there is two rows i'm assuming fluid out and fluid in. some of the hoses screwed directly into the pump and some of the had a nipple that screwed into the pump and then the hoses screwed onto the nipples. some of the nipples when you shook them rattled which i assume is some kinda backflow or something. i think i got some mixed up because the arm moves a little and stops. i assume the backflow is sealing off the fluid. does anyone know whick hoses get the nipples with the backflow device.
/ ford 4500 backhoe #2
see if this helps, your 4500 should have the 19-755 15' hoe on it
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2020 CAT 308 (A53317)
UNUSED IRANCH IRTPL 10000Ib TWO-POST CAR LIFT (A60432)
UNUSED IRANCH...
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Peterbilt 579...
