Ford 445a steering issues
   / Ford 445a steering issues #1
Shawng
Ford 445a
Hello,
Oil is leaking near the steering wheel out of the top of the column onto the dashboard. I took off the steering wheel and top bushing and noticed the bushing was pushed out of the column. The upper steering column is full of oil. Is that normal? Noticed bits of metal shavings. Do I have to take off the entire dashboard in order to get into the column so I can inspect seals/replace, etc. What might be causing this issue? Is this a motor or pump issue?
Any suggestions would be great.
Happy Holidays,
Shawn
   / Ford 445a steering issues #2
Hello,
No.
Yes.
Steering valve seal failure and possible rough/pitted surface on shaft.
Valve/motor.
Happy Holidays,
Shawn
Answers inserted.
Thank you for the quick and helpful reply, Rick. Really appreciate it.
Take care,
Shawn
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A55787)
2017 JLG Skytrak...
2019 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2019 CATERPILLAR...
UNUSED LANDHONOR LDH-FPR36 - 36" FIRE PIT RING (A54757)
UNUSED LANDHONOR...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A55787)
2025 GIYI VR66...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
