Ford 445 won't go in reverse
   / Ford 445 won't go in reverse #1
Ford445
Oregon, USA
Ford 445
My Dad's 1983 Ford 445 now suddenly won't go into reverse. This has happened on about 3 other occurrences in the past but it always seems to work eventually and work great for a very long time. Any suggestions on what this might be? I'm assuming it's not a mechanical issue but possible electrical (maybe switch or solenoid)? It has a 4 speed manual with power reversing transmission (forward and reverse). Forward works fine.
Wondering if there is a fuse or solenoid to check. Anyone have a suggestion how to access the compartment under the instrument panel?
**UPDATE** I know you guys were busy all day/ all night pondering my question, but while you were doing so, I fixed it! :) Turns out the shift lever wasn't giving the transmission enough throw to engage reverse. I loosened the bracket holding the shift lever and it gave the shifter enough give to engage reverse successfully! :jump:
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
2022 CATERPILLAR 299D3 SKID STEER (A52709)
2022 CATERPILLAR...
