3-Point Hitch Ford 445 3 Point Stabilizer Bars
   / Ford 445 3 Point Stabilizer Bars #1
Ford445
Oregon, USA
Ford 445
Looking for input in regards to the Ford 445 3-Point Stabilizer Bars. The ones that came on my tractor have been bent and re-welded at some point. What do you guys recommend as a replacement? I see them on the New Holland parts website but I'm not sure if they are even available. The tractor has the stock Gannon box scraper attached to the 3 point. Thanks in advance!
   / Ford 445 3 Point Stabilizer Bars #2
You could try for the stock turnbuckle type or ther may be the newer telescopic type available for your tractor.
   / Ford 445 3 Point Stabilizer Bars #3
have you tried tsc stores?
   / Ford 445 3 Point Stabilizer Bars #4
Cross Creek Tractor seems to have a good assortment of 3 point hitch parts for Ford tractors. They do show lift arms for a 445. They could likely tell you if the telescoping stabilizers they sell will fit since they have them for most ford tractors.
Ford Tractor Three Point Hitch Parts
   / Ford 445 3 Point Stabilizer Bars #5
Stabilizer Bars have to be straight to work. As soon as one is bowed, the other one will soon get bowed too. They only work in tension, or pulled....they don't work being pushed as they are thin and all they do is bow. I have seen some made that has a slot in the one end so they never bow. If the OP has different width implements, it makes it difficult to determine the exact hole-to-hole measurement.
   / Ford 445 3 Point Stabilizer Bars #6
Stabilizer Bars have to be straight to work. As soon as one is bowed, the other one will soon get bowed too. They only work in tension, or pulled....they don't work being pushed as they are thin and all they do is bow. It seems to me that the ones the OP has are too long. I have seen some made that has a slot in the one end so they never bow. If the OP has different width implements, it makes it difficult to determine the exact hole-to-hole measurement.
   / Ford 445 3 Point Stabilizer Bars #7
^^^weird...double post happened 2 days after the first one????????:confused:
LOT: (5) Bolt Cutters (A59076)
LOT: (5) Bolt...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2009 CATERPILLAR 308D CR EXCAVATOR (A52709)
2009 CATERPILLAR...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
