Ford 4400
   / Ford 4400 #1
Lazyacres
Woodbury, TN
Kubota m8200 4x4
I have a 4400 that has a blue belly and yellow top. It has a loader. I am trying to find information about this tractor. Part of the serial number is missing.
   / Ford 4400 #2
A 4400 is a variant of a 3 cylinder 4000. The unit code will be more helpful than the serial number. Both, plus the model code, are found on the foil tag on the underside of the hinged half of the hood as well as hand stamped on the RH side of the clutch housing.
   / Ford 4400
Thanks. Is there any way to identify the model loader that is on it?
   / Ford 4400 #4
A Ford loader had a tag on the inside of the loader boom above or below the bend where the bucket tilt cylinders' base end mount. Might still be there. It is most likely a 735 if it is a full-frame Ford loader with crankshaft driven pump.
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
2016 E35 Bobcat Mini Excavator (A50322)
2016 E35 Bobcat...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2011 Ford F150 (A50515)
2011 Ford F150...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
