Ford 420 Fuel Sending unit
   / Ford 420 Fuel Sending unit #1
VTPSD
Starksboro VT
ford 420 industrial with custom turbo setup, diesel converted wheel horse
I am trying to get the gauges working on my 420 diesel. The fuel gauge moves up to full with the key on and stays there, if i unplug the sending unit, it drops to empty. I pulled the sending unit and tested it. It was something like 11ohms full and 38 ohms when empty, with a pretty even sweep. Do these numbers sound right or should I replace the sender or look elsewhere? The wiring all checks out good. Fuel gauge is very pricey!
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
199049 (A51243)
199049 (A51243)
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
