Ford 4000 SU
   / Ford 4000 SU #1
sawtooth
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
I have a 1971 4000 SU with a gazilion hours on it and the engine is finally starting to loose its power. I'm a good ways over 10,000 hours so figured its time. When i rebuild it should i overbore or should i use sleeves? I've heard both ways for these engines but want to do it the best not necessarily the cheapest. Thanks,
   / Ford 4000 SU #3
Yes, Agree with Rick,these engines are notorious for going porous,in my own case my engine was bored something like 200thou and heavy lipped liners were pressed in,back to original bore size. Liners were about $50 each some are cheaper but are also thinner, and many don't have the lip which has seen some ford owners left with dropped liners. They are reasonably cheap to rebuild IMHO
   / Ford 4000 SU
thanks guys for the info and sleeved it will be. Any idea on the cost to rebuild one of these 201's?
   / Ford 4000 SU #5
MY neighbor had a 4000 SU when I was growing up, I hauled a lot of corn out of the field with it. My favorite tractor of all time, good luck with it.
   / Ford 4000 SU
but reman's are overboard correct?
2006 CATERPILLAR D5G LGP CRAWLER DOZER (A51242)
2006 CATERPILLAR...
Peterbilt 377 Semi-Truck (A52128)
Peterbilt 377...
UNUSED FUTURE MINI EXCAVATOR RAKE (A51244)
UNUSED FUTURE MINI...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
