Ford 4000 SU parts book anyone?
   / Ford 4000 SU parts book anyone? #1
jimmychew
Bronze Member
Cub Cadet 1200
Hello all,
I am trying to identify some parts on a Ford 4000 SU and was wondering if anyone has access to a PDF parts book. I've tried the Ford/New Holland site and cannot find that model listed I also called them and they could not find it either!
I cannot read the tractor number on the tag, but the model number is D1414C. The closest I can estimate for the year is 1968 - 1975, three cylinder diesel, 8 speed trans, light duty front end and steering, non louvered tins, internal wet brakes, power steering fluid reservoir mounted on pump.
Thanks in advance for any help
:thumbsup:
   / Ford 4000 SU parts book anyone? #2
It would help to know what parts you need.
A 4000 SU is basically a 4000 engine, transmission and rear end with a 3000 front axle and steering system.
So when searching for parts type in those model numbers depending on what you need.
Those are Very good tractors.
Lots of power in a short, low package. With that girlie 3000 front end not the best for loader work tho.
Thanks ultradog for the reply. Right at the moment I'm lookin' for a new fuel tank.
   / Ford 4000 SU parts book anyone? #4
Interesting.
I know those tractors pretty well but that's a question I can't definitively answer.
New Holland does list the 4600SU which is identical to a 4000SU except for upgrades to the hydraulic and electrical systems.
For those they say the SU model uses the smaller tank like is on the 2600/3600 models.
26/3600 are identical to the older 2000/3000 models except again, upgraded hyd/elec systems.
Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
Thanks again for the info. I called F/ NH the other day and they had no idea. Referred me to a local dealer. Local dealer had no idea, said " they all use the same tank!"
I'm hoping that someone will have access to an original parts book from a 4000 SU.
Thanks again ultradog.
JC
I ended up taking a chance and ordering the tank listed for a Ford 3000 (Part No: C5NN9002AC) and turns out it fit perfectly. This is for a 1973 model year. And remember it needs a vented cap!
   / Ford 4000 SU parts book anyone? #7
AP and SU style Ford’s under discussion do use different tanks. The bottom of the tank is shaped differently. Sparex is the only source I know for the larger tank original or AP 4000 series tractors.
Hmmm... Interesting.
Thanks for the input!
2000 BMW  740IL (INOPERABEL) (A52472)
2000 BMW 740IL...
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
2006 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2006 KOMATSU...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2019 KENWORTH T680...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
