Ford 4000 Steering Wheel
   / Ford 4000 Steering Wheel #1
DrPhil
I've got a 1971 Ford 4000. I need to replace the rubber grommet beneath the steering wheel. I went to take off the steering wheel, but couldn't get the nut to budge. The nut was rusted, but I wanted to make sure I was turning it right....(don't want to cause more of a problem)
Is it rusted, is that my problem? It does unscrew to the left, right? Do I need a special tool?
   / Ford 4000 Steering Wheel #2
If it's rusty.. that's your problem.. Good penetrating oil and just keep working at it.. sometimes if you can manage to smak just the nut.. like using a socket to avoid the center, smack it medium force to swage the threads. You can also do this 'around' the flats of the nut if you can get to them. ( i don't have a 4000 to compair the steering wheel setup to )
don't deform the nut and shaft.. just 'medium' hits.. break rust bonds.. etc.
Soundguy
   / Ford 4000 Steering Wheel #3
I have a 1968 5000 that I replaced the steering wheel, cap and the rubber grommet. Best of my rememberance the nut unscrews counterclockwise. You will definitely need a wheel puller to get it off (steering wheel). I think your best option if you are not going to replace the wheel is to take a sharp single edge razorblade and carefully make a cut in the grommet, stuff the grommet in and let the cut be underneath the steering shaft. Probably will never even notice it. I've done it many a time.
Dave
   / Ford 4000 Steering Wheel #4
I like what Dave said, I had to replace the whole steering wheel one time and it ain't worth it. Cut the grommet.
NV
2013 Chevy Silverado 2500 HD (A53472)
2013 Chevy...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
