Ford 4000 rear rim parts
   / Ford 4000 rear rim parts #1
Duramax88
Louisville, Ohio
1966 Ford 4000 3 cylinder gas, 2003 Jinma 354 4x4 diesel
Hello everyone , I have a question about rim parts for my rear rims. I have 6 rail 12 x 38 spinout rims and need the following parts for the rim. The first part is a wheel nut (CONN1059A), the second is an adjustment screw (CONN1056A). New or used is okay. Any help would be appreciated.
   / Ford 4000 rear rim parts #2
I'd try going here TractorHouse.com | Used Tractors For Sale: John Deere, Case IH, New Holland, Kubota. first, and place a "want to buy" ad. This goes out to salvage yards, and may go to other dealers that may have some NOS parts too. Look on the left side of the page, 3rd item down in the menu. You'll have to register, and give some contact info. Put the part number, and description where it goes. Normally, anyone that may have some will contact you within 36 hours. Being this is Friday, I'd give it until next Tue. or Wed. I've found it best to not jump on the deal of first one to call. There is a possibility of getting more than several. Prices, and shipping can vary, depending on where they may be. I've received calls on parts within 45 minutes, up to approx. 36 hours.
I thought I may have found some of the adjustment screws at Steiner, but, they are the wrong diameter. It looks like yours are 7/8"-14, where these are 9/16 X 2-5/8". With that being said, the price on those are $8.99 ea. Just thought I'd add that info to save some sticker shock, if you would happen to try it, and get a call.
If by chance they would have the adjustment screws, but not the nuts, those should be easier to find. I did a quick check at McMaster-Carr, and they have more than several types. They have some Grade 8, 10 for $4.76, or on down, some extreme strength, 10 for $9.22. Here is the link for the page, at McMaster-Carr, if you want to look. McMaster-Carr.
Another option, would be if you have a local machine shop that does piece work. Take one of your adjustment screws to them, and see if they could make what you have, out of a 7/8-14 bolt. I don't know how much clearance you have, so type of head would have to be determined, for proper clearance. Usually with a machine shop, set up time is where a lot of the cost is. Not sure how many you need, but if it's all 24, then the price each might not seem so bad, compared to the above price of $8.99 ea. If it's affordable while their set up, maybe do a couple extra sets to sell to offset the cost of yours. This is just all food for thought, if you don't find some OEM parts.
There is one more thought, and a place to call. This is a small NH dealer North of Coshocton, OH., who may just have some NOS parts laying around. Approx. 16 years ago, I found a NOS 3 sp. aux. transmission, to fit my 2000. It had been on the shelf since 1973. They took it off the inventory, but squirreled it away. It is, or was a small family business, owned by a local farmer. Really nice to deal with. Here is the name, and contact info. Bakersville Garage Inc.
59507 CR 2
Bakersville Ohio 43803
Phone: 330-897-7561
Okay thank you very much I will try some of the suggestions and hopefully I will get some results.
   / Ford 4000 rear rim parts #4
PM me if you are still needing those parts. I also have a Ford 4000 and I replaced the spinouts with new "fixed" centers/rims because they were in bad shape. The spinout rims have been sitting out in the fencerow for about 4 years now. I will have to double check that they are 6 rail spinouts and not just 4 rail.
Yes please check and see how many you have, the price and shipping cost. Thank you for responding to my thread.
WESSEX AT110 LOT IDENTIFIER 157 (A53084)
WESSEX AT110 LOT...
UNUSED FUTURE FT2P 12 VOLT PUMP (A51248)
UNUSED FUTURE FT2P...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
49" X 79" EXPANDED METAL RAMP GATE (A51247)
49" X 79" EXPANDED...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
