Buying Advice Ford 4000 - need advice
   / Ford 4000 - need advice
Re: JD 4000 - need advice - oops
Yes, like that! /forums/images/graemlins/grin.gif I will check out the Iron Search, thank you!
   / Ford 4000 - need advice #12
Yea it's not near the deal then. That is about half the tractor of a JD 4000.
   / Ford 4000 - need advice #13
or twice the tractor, if it'll get into twice as many places that the Deere won't
   / Ford 4000 - need advice #14
</font><font color="blue" class="small">( or twice the tractor, if it'll get into twice as many places that the Deere won't )</font>
LOL............
A little more info - 787 hours, diesel - to answer some of your questions. It apparently was kept under cover for quite a while, but hasn't been for the last several years. The bushhog it comes with is at least 5', might be 6', but haven't asked or measured.
   / Ford 4000 - need advice #16
JBANDRIO
Sounds like a good tractor. I have a Ford . 4000 and love it /forums/images/graemlins/smile.gifseems I can put 5 gallons of diesel in it and run it all day. If it has been setting outside besure to check the the oil bowl on the air filter. I let mine set outside for a winter and rain water drained down in the bowl over filling it did not discover it untill I had cranked it and ran it for a while in the spring. After I saw that thought I was lucky it did not suck up the water/oil into the cylinders and damage the motor.
Good luck,
BTW if you purchase the tractor how about posting a few pics.
BigWill
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
Nissan 50 Forklift (A54865)
Nissan 50 Forklift...
2018 Ford Transit Van, VIN # 1FTYR2CG5JKA96646 (A54865)
2018 Ford Transit...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
