Oil & Fuel ford 4000 injector pump
/ ford 4000 injector pump #1
JRA29
I have a 1970 ford 4000 diesel. It wouldnt crank so i changed fuel filters and notices the wrong filter was attached, after getting the right one still not cranking, fuel is getting to the pump and loosing the small 5/16 bolt on the side of the pump and fuel was squirting out there when running on ether, but not coming out the injector lines. Just wondering if i should go ahead and pull the pump or is there anything else i can try.
/ ford 4000 injector pump #2
yea pull the pump the head in the pump is most likely twisted off or an impeler brooke
/ ford 4000 injector pump #3
fuel shutoff may be stuck closed..
soundguy
/ ford 4000 injector pump #4
If you're getting fuel to the injection pump and it isn't pressurizing the lines to the injectors, it probably means you're ready for a pump rebuild.
/ ford 4000 injector pump #5
soundguy
that can happen but i can be a tricky job to fix and must likely if u have trash there u have trash somewhere else in the pump so u should have it cleaned
Thanks for the input. I have started pulling the pump off i have never done this before I got everything loose form the pump but it still wont come out of the hole of the tractor. Is it something holding it inside? i notices a cover that i could take off on the other side of the pump.
/ ford 4000 injector pump #7
yes under that cover there is three bolts that has to be removed before the pump can come off. and it is very easy to time because there is a dial pin in the gear that the pump is bolted to and a grove cut into the front of the pump and that is all u have to line back up.
thanks ill give it a try
/ ford 4000 injector pump #9
oh.. and don't spin the starter over once you pull the injector pump.
still.. I think I might have just taken the top off.. be carefull about parts and all.. etc.
your call.
soundguy
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
2015 INTERNATIONAL PROSTAR+ (A67714)
2015 INTERNATIONAL...
213090 (A64276)
213090 (A64276)
2008 Generac SD100 T3 125kVA Standby Diesel Generator (A66734)
2008 Generac SD100...
7 foot bucket (A64194)
2021 CATERPILLAR 259D3 SKID STEER (A65056)
2021 CATERPILLAR...
