Ford 4000 hydraulic's for loader
   / Ford 4000 hydraulic's for loader #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
Was using my freinds Ford 4000 for loading some horse poo yesterday and encountered a problem that I was hoping someone here had seen.
I may not have enough details, but here is what I believe to be true.
It has a great bend loader.
It has what clearly appears to me to be an aftermarket loader control (I suspect it is a GB) mounted on the right fender.
The loader Hydraulics come off ports in the back behind the seat, and loop to the control.
there is a fore and aft "diverter" control directly under the seat, which if I am understanding correctly is changing my hydraulic flow from the loader to the TPH.
The "diverter" lever, is just above the TPH control, which travels in an arc up and down.
While using the loader, I beleive particularly when under heavier loading, the diverter lever constantly pops "forward" which is the TPH position. So, as you are utilizing the loader, it constantly stops operation till you reach under the seat and push the "diverter" lever to the rear and it will again operate.
My buddy was thinking possibly that it was a filter problem or something similar.
I figured I would lay it out here and someone would have probably experienced this in the past and could point me in the right direction to start looking.
I do not see the tractor daily, but if more details are needed I do have access too it and can obtain additional data.
   / Ford 4000 hydraulic's for loader #2
Sounds like a weak detent int he diverter, and the hyd load is forcing the spool to move and to 'kick' out.
Me? I'd bunji it down and go.
Soundguy
   / Ford 4000 hydraulic's for loader #3
Soundguy
Oh, that's real good advice. Now watch the bungee break and the hook come back and take his eye out. ;)
   / Ford 4000 hydraulic's for loader #4
Double hook the end.. IE.. have both the hook ends on the? runningboard, and only the bunji body over the valve handle. If a hook end comes off.. nothing to slap back but a piece of rubber or fabric wrapped elastic strands..
soundguy
   / Ford 4000 hydraulic's for loader #6
I did.. but figured I would add in how i like to bunji stuff, when i do bunji it... It's no fun getting hit with a hook end..
soundguy
   / Ford 4000 hydraulic's for loader #7
Just remember, your eye is like an egg, it runs when poked.
   / Ford 4000 hydraulic's for loader #8
Speaking of poked eye.. the wife managed to poke hers last week with the earpiece of her reading glasses. 2 trips to the eye doctor later, plus 3 different eye drops and lots of diagnostic testing and she is now good to go again. minor corneal abrasion...
soundguy
John Deere 4040 Tractor (RUNS) (A50774)
John Deere 4040...
2014 John Deere 644K Articulated Wheel Loader (A50322)
2014 John Deere...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
