ford 4000 hydraulic problem
   / ford 4000 hydraulic problem #1
chrisinnc
apex NC
ford 4000
Hello Friends,
I have a 1970 Ford 4000 3 cyl diesel. It has new hyd fluid topped off to the proper level. The lift was working fine then it suddenly lifts only an inch or two and no more. I have checked for mechanical interference and it has the same problem even with the lift arms disconnected. I am waiting for a manual before digging in any further. If anyone has experienced this problem or can offer any suggestions it would be greatly appreciated.
   / ford 4000 hydraulic problem #2
Make sure the draft lever is in the vertical position. It's possible that the draft pin is worn through.
Thanks for the idea. I tried that with no luck, I guess I will be tearing it apart when the manual arrives.
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
2014 PETERBILT 367 (A50854)
2014 PETERBILT 367...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A49461)
2007 Bomag...
RIMS AND TIRES (A50854)
RIMS AND TIRES...
GENERATOR HOUSE POEWERED BY TWIN 550HP (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
