Ford 4000 Front Loader :confused:
   / Ford 4000 Front Loader :confused: #1
08mckerp
Hi, ive recently purchased a Ford 4000 2wd and am looking to put a front loader on it. Has anyone got any suggestions on what is gd and what to avoid. Thanks in advance!
   / Ford 4000 Front Loader :confused: #2
We at Koyker would be happy to quote you a loader it would be a model 220. Give us a call at 800-456-1107
Thanks,
Scott
   / Ford 4000 Front Loader :confused: #3
Make sure you get something with the skid steer style mount. But I'd be careful of Koyker because right I'm having problems with my Koyker SS Mount that I just started using. Not sure if its the mount that's the problem or if its the attachments.. I have two different attachments and both are giving me trouble so I'm leaning toward the mount from Koyker. Other than that they are a wonderful company and easy to work with. I can guarantee it will fit like a glove and everything comes ready to go.
Wedge
   / Ford 4000 Front Loader :confused: #4
There are a LOT of tractors under the Ford 4000 name. Be sure you know the cylinder count, year, model, etc.
Koyker makes a fine loader. So does Westendorf. If you can find a used factory loader the price will be lower, but expect to fix welds and repack cylinders maybe replace the valve too. 30-40 years of use takes a toll.
jb
Ok thanks. Will the fact that it has a cab affect the type of loader it will take? Thanks
   / Ford 4000 Front Loader :confused: #6
If you go to Koyker web site they you can see if they have one to fit the 4000 with a cab or not. From my quick search it looks like they dont have one that work with a cab. But without the cab you can use a 220 loader.
I would call Koyker and see what they tell you.
Wedge
   / Ford 4000 Front Loader :confused: #7
A new Koyker or Westendorf would be a great choice....however, I am a bargain shopper and where do bargain shoppers go? Ebay. There is currently an auction running for a factory Ford loader for your model, "no breaks, bends or welds" with rebuilt cylinders that will sell for probably less than 25% of what a new FEL will cost. You always have to contend with "is it close enough to justify getting it" when buying large items from ebay but patient watching is the key and the best deals I have gotten have been purchased this way. I see these used loaders very often on the net.
   / Ford 4000 Front Loader :confused: #8
120378493782
   / Ford 4000 Front Loader :confused: #9
make sure you are deciding between a 3cyl 4000 and a 4 cyl 4000.
soundguy
2003 Big Tex 10PI...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
HAMM HD120HV DOUBLE DRUM ROLLER (A52707)
HAMM HD120HV...
