ford 4000 flywheel removal
   / ford 4000 flywheel removal #1
wink4000
cornish, maine
ford 4000
Hey guys,
I have split my tractor between engine and transmission in order to seal a soft plug (cast plug, freeze plug w/e) behind the flywheel. I am having trouble removing flywheel and am in need of help. I have a 1968 ford 4000 with select-o-speed transmission. When I split it there is a shaft coming from middle of flywheel that inserts into what must be the back end of the clutch? It looks like this shaft needs to come off in order to access the bearing and flywheel for removal. I have tried hitting flywheel (below teeth) with soft hammer, prying, turning, hitting, prying etc. it seems to have no effect and want to ask before I hit harder:p.
   / ford 4000 flywheel removal #3
When I encounter a problem like this ...Blow air to remove dust thats loose....then lub and air to forse lub in...preybar to start movement ...lub and air and tap back...spray lub and air and prey again...it will start loosening with the smallest movement...keep on doing that....
2023 John Deere 6155M MFWD Tractor (A53342)
2023 John Deere...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
