Oil & Fuel Ford 4000 CAV Injection Pump Issues
   / Ford 4000 CAV Injection Pump Issues #1
DSMurphy
Ford 4000
Help... I have a Ford 4000 3 Cylinder Diesel that has been sitting for about 3 years and now it will not start. I used to start with no issues. I originally thought that it was a fuel issue. I have bleed to the filter (diesel with no Bubbles) and bleed to the CAV injector pump (diesel with no bubbles) but cannot get Diesel to the injectors(throttle is full on). I have read many suggestions on the internet and tried them so of them with no luck.
-Jacked the front of the tractor up a bit and re-bleed the system.
-Taped the side of the injector pump with a hammer while moving the fuel shut-off level
I think the fuel shut-off valve is stuck in the injector pump. Is there any way to release it without removing the pump? I'm not sure I can remove the pump with taking the front end loader off which would be a BIG job!!!!
The tractor is 6 hours away from home and have no internet access there so I'm trying to get some help/suggestions before I go back and try again.
Any suggestions would be much appreciated.
   / Ford 4000 CAV Injection Pump Issues #2
There are a thousand instructions on the web on how to get the cover off..alot written by me.
Just "floogle" cav top cover leak.. That'll explain the tc removal & the metering valve is right there..
Once the MV is free & moving, bleed the system again & try to start.. IF it wont pump THEN.. the pumping plungers deep inside the pump are stuck too..
Hope it pumps.. if not, lemme know.. TPG
Thanks I will try this the next time I'm there....
2019 Chevrolet Tahoe (A52377)
2019 Chevrolet...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53472)
UNVERFERTH 330 -...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
