Ford 4000 boiling over.
   / Ford 4000 boiling over. #1
funny farmer
northren mn
ford 4000
I posted this on the ford, new holland board, but I thought that I would get some more advise on this one. I have a Ford 4000, 1968ish model, 3 cylinder, gas engine. I've had this problem for a few years now, but it seems to be getting worse every summer. She get's hot, so hot that it will boil the water out of the radiator. Even in the winter time when I'm working it hard. In the summer when I'm making hay, every time I gas it up I have to add a couple gallons of water, I've been dealing with it as best as I can, but it's time to fix it. Last summer it got so hot sitting on the tractor that it was unbearable. I could feel it from the left side, like the heat from the exhaust was creeping through the front of the tractor and onto me. The gas tank would get so hot that I could hardly stand to touch it, and I don't think that痴 normal. The exhaust will blow in my face all day like it's not getting up high enough to blow away from me, I could hardly breath, it was pretty miserable. A few years ago I had a neighbor look into it and all he did was straighten out some ribs on the radiator, said it should be good to go. That didn't help any. It's not the thermostat either, I took that out and it still runs hot. The guy that I bought it from told me that it sounds like it needs new head gaskets. I asked him why he thinks that, and he told me that it builds up pressure inside the head and pushes back out the radiator, it makes sense to me, and that痴 why it's hot, because not every part of the engine isn't getting coolant. I was wondering if anyone on here has had the same problems and if that was the solution? I've got the service manual for this tractor, and it didn't look like that big of a job, but I didn't want to bite off more then I could chew either. I kind of worry about taking the rocker arm assemble off and having push rods and valves falling all over the place. Maybe it would be a good time to get a valve job done on the tractor. What say you?
   / Ford 4000 boiling over. #2
Try putting the correct thermostat back in. If a thermostat is removed the water will circulate too fast through the radiator to cool it. You will then have hot coolant going back into the engine and not be able to cool it.
   / Ford 4000 boiling over. #3
I replied to your post in the Ford/NH forum.
Put t-stat back in. Pressure test cooling system/block.
It finally made some sence about the thermostat:) sometimes I'm slow, Thanks F.W.J.
   / Ford 4000 boiling over. #5
I also replied to your post in the other section.
making 2 posts in different sections makes it harder to follow the thread progressions and is generally frowned upon..
soundguy
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
John Deere 825i Gator (A50514)
John Deere 825i...
2015 WESTERN STAR 4900 SF (A50854)
2015 WESTERN STAR...
2014 JOHN DEERE GENERATOR SET (A51222)
2014 JOHN DEERE...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A51039)
2-Row Peanut...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
