Ford 4000 3 cyl coil 6v 0r 12 v
   / Ford 4000 3 cyl coil 6v 0r 12 v #1
bach939
Michigan
Ford 4000 3 cyl
I have a Ford 4000 3 cyl tractor 12 v system. It has a 6 volt coil that is bad. I believe there is a resistor wire that is about 3 ft long that is plugged into a wire harnes of which goes to the ignition switch. By mistake, I purchased a 12 v coil to be used with an external reistor. Can I use this 12 v coil and if so do I need to add a ceramic type resister with or with out the current resistor wire?
   / Ford 4000 3 cyl coil 6v 0r 12 v #2
Spark ignition systems on these older tractors are limited to about 4 amps max primary current. Thus a "12V" coil has ~ 3.2 ohms primary resistance and a "6 V" coil has ~ 1.6 ohms primary resistance. A 6V coil can be used on a 12V electrical system by using a resistor to limit the primary current. However, a 12 V coil should not be used on a 12V system with any additional resistance in the primary circuit (normal wire resistance excluded).
The exception to this rule is there are some so called 12v coils that say "must be used with external resistance". These are in fact a 1.6 ohm coil and must be used with additional resistance in a 12V electrical system. If this is what you purchased, then your existing resistor wire should be sufficient and you should not add any more resistance to the primary circuit.
I hope I haven't succeeded in confusing you.
   / Ford 4000 3 cyl coil 6v 0r 12 v #3
It's considered poor form on TBN to post the same question in more than one thread, just sayin
Jim
Jim
Sorry, new to the forum and was desperate to get answers to get the tractor running.
BAUMA LIGHT TX 12 LOT NUMBER 240 (A53084)
BAUMA LIGHT TX 12...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
2015 ford f350 4x4 mechanic SERVICE TRUCK (A52377)
2015 ford f350 4x4...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
John Deere 5400 Tractor with Loader (A51573)
John Deere 5400...
John Deere 1025R with Loader (A51573)
John Deere 1025R...
