Ford 3930
   / Ford 3930 #1
icelinn
Fairmont, West Virginia
Ford 3930
I just replaced the starter solenoid on my 3930. It was making a long ccccllliiickkk (Click) before engaging the starter. All wiring put back the same, now the tractor tries to start with the kill switch out and the key off, the the starter was on a continuous whirrr until I got the battery terminal disengaged....HELP !
   / Ford 3930 #2
The mechanical connection between the new solenoid and the starter drive isn't correct. Linkage is jamming the solenoid contacts together while preventing the drive from engaging the ring gear.
   / Ford 3930
I took it off again and it appears the bendix is locking. I checked to see if the "arm" in the starter was free when the solenoid kicks. Being really confused I'm taking it to a shop to get then to check it. Thanks for your help
CAT ENGINE ( NON- RUNNER) (A50854)
CAT ENGINE ( NON-...
RIGID TOOLBOX (A50854)
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
Unused Delta Crash...
MCELROY 500 SERIES 3 TRACKED FUSION MACHINE (A50854)
MCELROY 500 SERIES...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
