Ford 3930 won't turn over
   / Ford 3930 won't turn over #1
rowellc
Crestview, Florida
Ford 3930
I have a Ford 3930 and the starter won't turn over. I replaced the battery. The old one was going dead but the new one is fully charged and the starter still won't turn over. The past weekend it would turn over and then other times it would just click when I turned the key. this was with the old battery. With the new battery it would not turn over at all.
Any ideas on what the issue is.
   / Ford 3930 won't turn over #2
I have a Ford 3930 and the starter won't turn over. I replaced the battery. The old one was going dead but the new one is fully charged and the starter still won't turn over. The past weekend it would turn over and then other times it would just click when I turned the key. this was with the old battery. With the new battery it would not turn over at all. Any ideas on what the issue is.
Try tapping the starter motor with a ball peen hammer. Could be sticking or on the way out.
   / Ford 3930 won't turn over #3
Don't tap too hard, usually a "click" is a bad ground or the solenoid is going.
   / Ford 3930 won't turn over #4
Any luck?
   / Ford 3930 won't turn over #5
If you decide to remove the starter, good luck getting at the third bolt that holds it on. Miserable job, bloody knuckles.
   / Ford 3930 won't turn over #6
We assume you've double checked both battery cables, where they attach must be clean. Some develop internal breaks that limit current flow. Try that before removing starter. AND, try jumping from new battery cable end at starter to small terminal there to be sure you don't have an ignition switch problem. In neutral if course.
Jim
   / Ford 3930 won't turn over #7
Jim
Good advice. I did bloody my knuckles to find the starter was OK, the ignition switch was the culprit.
It was the starter. It had a loose wire that was grounding out.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
