Ford 3930 PS fluid & safety switch questions
   / Ford 3930 PS fluid & safety switch questions #1
Jason280
Ga
Kubota L4330
I have a mid 90's Ford 3930, and has developed a couple of issues. First is a problem with steering at lower RPMs, which I have narrowed down to a low/almost empty PS pump reservoir. Any particular fluid I need to run in the Ford for the power steering? Will universal tractor fluid be adequate? Also, the reservoir does not have a dip stick, do I simply fill to the bottom of the filler neck?
Second issue is occasionally, the tractor will flat out not crank. No noise, nothing. I'm narrowed this down to either the PTO safety switch, or more than likely, the neutral safety switch for the "Low - High" selector. What is the best way to troubleshoot the switches? I know there are two wires going through the shifter plate cover, but I am not sure how the switch works. Does it simply ground out?
Thanks!
   / Ford 3930 PS fluid & safety switch questions #2
I think the fluid ofr the peower steering is power steering fluid. If you have the small external power steering pump, remember there is a filter in there that needs changing about every 1000 hrs.
I think it is a simple open/close circuit switch. It may be in series with other switches so all the swithes have to be closed to get current to the solenoid.
   / Ford 3930 PS fluid & safety switch questions #3
Do not use power steering fluid designed for cars. Use New Holland hydraulic fluid. The automotive ps fluid will ruin seals.
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
1997 GROVE TMS750B 50' TON CRANE (A51222)
1997 GROVE TMS750B...
2017 BIG TEX 16 T/A UTILITY TRAILER (A50854)
2017 BIG TEX 16...
