Ford 3930 FEL Cylinder leaking
   / Ford 3930 FEL Cylinder leaking #1
jlanglois
Ford 3930
The right side cylinder on my Ford (New Holland) 3930 front end loader (Model 7309) has started leaking.
Should I look for a re-build kit or just buy a new cylinder.
Any video's on how to repair that?
Thanks.
   / Ford 3930 FEL Cylinder leaking #2
   / Ford 3930 FEL Cylinder leaking #3
Well, there are kits from New Holland, but they are $175+. You would need to know the cylinder number stamped on the barrel if you want to order from Messicks or any New Holland dealer.
Other options are, take to a local shop and have resealed or take apart and match the seals.
Here is a video:
+1
Thank you Tractor Tech. That kit is now $258.00 at Messicks.
However, I was impressed at how quickly the got me a replacement brake release, even though I can't figure out why that should cost more than about $80.00.
   / Ford 3930 FEL Cylinder leaking #5
IF the rod isnt scored, and the thing isnt bypassing.....just replace the gland seals. Done it many times.
Its easier on most cylinders with a threaded rod end....but most loaders have a welded cross tube so you gotta knock the piston off to pull the rod out of the gland.
But either way, local hydraulic shop....I have never paid more than about $20 for a gland seal. And if the rod isnt scored or has chipped chrome.....no need to replace the expensive rod
   / Ford 3930 FEL Cylinder leaking #6
However, I was impressed at how quickly the got me a replacement brake release, even though I can't figure out why that should cost more than about $80.00.View attachment 814564
Well, Messicks doesn't set the price and that brake handle/rod and tractor are "Legacy" items. Plenty of old and used parts out there. That is just not a popular part so no aftermarket options.
I found a local shop that rebuilt my cylinder for $200.00 I guess they must make their own seal kits.
It's working great.
   / Ford 3930 FEL Cylinder leaking #8
I always do both cylinders at the same time. Early on I would always just do the one leaking, after about the 6th time of the companion cylinder leaking within a month or two of the first repair, I learned that the fluid just blows out the weaker of the 2. Both cylinders need to be of equal seal strength.
There are 4 cylinders total. Two rotate the bucket and two lift the arms.
Having replaced the rotate the bucket cylinder, the lift the arms cylinder is now leaking.
Does the viscosity if the hydraulic fluid matter in this context?
Thanks.
   / Ford 3930 FEL Cylinder leaking #10
No. Since the loader seals gave out after all these years, it is not surprising that the bucket cylinder seals are now leaking.
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
Commercial Truck Frame with Axle (A55852)
Commercial Truck...
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
Informational Lot - Financing (A56435)
Informational Lot...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500...
