Ford 3910 Wet Line Kit install help and questions
   / Ford 3910 Wet Line Kit install help and questions #11
I've never used one. I've saw that knob. Maybe a Pilot Lock or a flow restrictor? You'll figure it out once you start using it.
My 3910 has dual rear remotes and I often use them both.
Rear hydraulics greatly broadens a tractor's useability.
   / Ford 3910 Wet Line Kit install help and questions #12
Thanks for the info! Got it installed over the weekend and everything seems to be working as it should with no leaks. It was more work making the coupling bracket fit than it was installing the valve. Any idea what the little turn valve on top of the block is?
I tried it both ways and full open gives the fastest response. Must be a flow control valve like you would want on a drag type disc harrow to keep it from hitting the ground too hard (can break off sections of blades, bad on axle bearings too)....so you screw it all the way in. Otherwise all the way out.
On the bracket I noticed the instructions said you might have to modify your seat to get it to fit. I had the popular seat with the separate tilt back and extensions to the side and it interfered. Just happen to have a new dish type seat that is standard issue for the 3910 and put that on. Having done that the bracket easily fit. Whomever designed my kit got the hose lengths perfect. Not too long to get rubbed by the lift arms and not too short to prevent the couplers from working properly.
Glad you got it fixed.
SAMSUNG FRIGERATOR W/ DRAWER FREEZER (A57192)
SAMSUNG FRIGERATOR...
Mailbox (A55853)
Mailbox (A55853)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
(4) ROLLS OF MISC CARPET (A54757)
(4) ROLLS OF MISC...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
