Ford 3910 Steering Hydraulic leaking oil
   / Ford 3910 Steering Hydraulic leaking oil #1
Braga-Portugal
Ford 3910
Hello all,
I need your help with my Ford 3910, the hydraulic from steering is leaking oil, see images in attached.
Can anyone help me figure how to disassemble it to change the sealants?
Best regards,
Carlos Oliveira
   / Ford 3910 Steering Hydraulic leaking oil #2
You can get a seal kit for that cylinder from a New holland dealar, it is a seal, a snap ring and maybe an O ring (I don't remember). That is as far as the cylinder is serviceable.
Hello,
I know about the repair kit, my doubt is how to change it.
Is it enough to take out the retainer clip and the seals come out through the front of the cylinder?
   / Ford 3910 Steering Hydraulic leaking oil #4
Yes the seals come out through the front of the cylinder (front being closest to the front axle). A pick helps to dig the inner piece out, it isn't a hard task but can be a booger to get the new one in, just take your time finessing it and it will go right in.
This video should explain it: Ford 3 power steering part 3. - YouTube
Hello all,
I´ve checked the sealer and it´s damaged, but i cannot find a equal one here in Portugal, can you advise me a store online where I can buy it?
Thanks again for the help
   / Ford 3910 Steering Hydraulic leaking oil #7
I'm not sure about Portugal. I use this site to order parts. I am required to select a dealer and I use Messick's which is a sponsor of this website.
Case New Holland Online Parts Store
You might be able to go straight to Messick's website also.
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
BROWN BDH-600 LOT NUMBER 174 (A53084)
BROWN BDH-600 LOT...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
