ford 3910 starter
   / ford 3910 starter #1
parc0821
Okeechobee, FL
ford 3910
How do I remove a starter on a Ford 3910 3 cylinder diesel tractor? It has hydraulics in the way for clear access to starter. I am trying to change the solenoid (the old one crumbled) and can't get center plunger of old one out. I figured I would have to take the starter out but can't get to inside bolts. I am lost.
   / ford 3910 starter #2
I've done this. There's no trick other than lots and lots of cussing and time. I can't remember exactly what I used to get onto the inside bolt, but I do remember I could only turn it about a millimeter at a time. Took forever. Also, I did disassemble/remove all the hydraulic bits that were in the way.
Sorry to not have better news. Maybe someone else will chime in with a trick.
Good luck!
   / ford 3910 starter #3
9/16" 3/8 drive 6 point flex socket. 6" extension. Ratchet. Remove the fuel filter. Use tools to remove the upper rear starter bolt WHILE THE OTHER 2 BOLTS ARE STILL TIGHT.
1996 NEW HOLLAND 3930 WITH LOADER (A51243)
1996 NEW HOLLAND...
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
1,000 Gallon Horizontal Fuel Storage Tank with Pump - Farm or Construction Ready (A51039)
1,000 Gallon...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
3in Poly Pipe (A49461)
DEWALT ROTARY HAMMER (A50854)
DEWALT ROTARY...
