Ford 3910 starter issues
   / Ford 3910 starter issues #1
Pal333
Brighton, mi
Ford 3910
Good to be part of the forum. I have a ford 3910 with a Perkins 3 cyl. Diesel. I'm in the process of putting a new starter on. That's what brings me to the forum. I've been having trouble starting. My son took the solenoid apart and reassembled it. When I charged the battery and tried to start the tractor, smoke came from the starter. I'll be looking for some direction on connecting the wires to the new starter.
   / Ford 3910 starter issues #2
Ford tractors don't have Perkins engines. Ford and Perkins both used CAV fuel injection pumps and filters; that's about all they have in common.
Positive battery cable and accessory feed wires (2) connect to the upper stud of the solenoid. Solenoid trigger wire has a female spade and connects to the male spade on the solenoid. Battery ground cable connects to a stud on the front cover of the starter or to a starter mount bolt. lower stud on the solenoid connects directly to the starter motor. Nothing else goes on that stud.
   / Ford 3910 starter issues #3
Welcome from Oklahoma.
Ken
Thanks Rick. Heading to michigans upper peninsula to install a new starter this weekend. Your heels is greatly appreciated!
   / Ford 3910 starter issues #6
Welcome to TBN :)
I moved your thread to the Ford/New Holland Owning & Operating forum.
2015 MACK GU713 (A50854)
2015 MACK GU713...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2021 FREIGHTLINER...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
