Ford 3910 Leaking fuel near carb
   / Ford 3910 Leaking fuel near carb #1
cj47
Comer, GA
Ford 3910
I had a stick pop up and hit the area in the picture below. it is now leaking fuel through the bottom of what I assume is the carberator. Anyone have any idea how I can fix this? I have looked for cracks and cant find where it is coming from.
   / Ford 3910 Leaking fuel near carb #2
Diesel - injector pump damaged?
   / Ford 3910 Leaking fuel near carb #3
If you think that is a carburetor the best way to fix that is find someone in your area familiar with diesel engines and injection pumps to fix your tractor on a fee basis. You are not qualified to repair it yourself at this time.
I'm not trying to be mean, I'm trying to help.
   / Ford 3910 Leaking fuel near carb #4
What RickB said. Injector pumps are best left to folks that do that type of work a lot. I am sure that in your area some independent mechanics specialize in that type of work. If not your dealer can repair it.
2021 JOHN DEERE CP690 LOT IDENTIFIER 182 (A53084)
2021 JOHN DEERE...
RYOBI EASY START INVERTER GENERATOR (A51248)
RYOBI EASY START...
HOMEMADE 4' X 12' SINGLE AXLE TRAILER (A51248)
HOMEMADE 4' X 12'...
CONTACT INFO LOT IDENTIFIER 6 (A53084)
CONTACT INFO LOT...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
