Ford 3910 hydraulic steering cylinder leaks - can't get off
   / Ford 3910 hydraulic steering cylinder leaks - can't get off #1
sawyer22
Churchville, ny
john deere 3720
The right side power steering cylinder on my 1986 Ford 3910 tractor cracked along the long seam of the tube and leaks fluid. The cap from the reservoir was missing and I think water got in and froze.
Can the cylinder tube be welded or rebuilt? The problem is that I can not get the rear (tie rod) end to come off so that I can take cylinder to be looked at. I've used a pickle fork but won't come loose - any ideas? thanks
   / Ford 3910 hydraulic steering cylinder leaks - can't get off #2
hit the metal where tie rod bolt goes thru, not the threads. a couple good licks with a hammer it should come off. if you have room hold a hammer on back side when you hit it, don't be afraid to hit it hard
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
UNUSED RAYTREE RPRB72-72" POWER RAKE BUCKET (A51248)
UNUSED RAYTREE...
2020 JOHN DEERE 331G SKID STEER (A51246)
2020 JOHN DEERE...
JOHN DEERE Z530M LOT NUMBER 77 (A53084)
JOHN DEERE Z530M...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
